Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
How to remove stripped logic board screw?
I recently followed the guide on replacing the hard drive in my mac mini.
I ended up being successful, however in attempting to loosen the logic board screw to allow room to to seat the hard drive as the instructions indicated, the screw was so tight I stripped the screw. After quite a lot of struggle I seemed to get the drive seated and it is functioning.
Is there a way to loosen the screw for any future issues?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
If you have some of the head left then you can try and apply more pressure and turn the driver slowly.
If it is completely striped, then your options are pliers or drill.
If you can get needle nose pliers on the head and have enough grip to turn it, turn slowly, and be careful not to scrape the board.
You can also use a drill with a drill bit as close to the same size of the screw as possible and apply some, not a lot of pressure, straight down and use the lowest speed to slowly drill the head away, once the head is off you can remove the rest of the board and use pliers to remove the remaining screw.
Indice 3
1 commentaire:
Thanks . I think I will wait until I need to attack that project if I have to.
The drive is installed and working as of now .
par
Comment enlever une vis cassée
Theres a great guide on a few ways to do that.
Indice 1
1 commentaire:
Impact driver set works well too. But that is last resort before going to cutting tool.
par
Ajouter une réponse
b biggs sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 600
