Aller au contenu principal
Sortie en juin 2016, s'identifie au numéro de modèle A3003 en Europe et A3000 en Chine et en Amérique du Nord. (Source : https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
20 questions Voir tout
LCD + Frame Replacement
Third parties offer the LCD screen replacement with or without FRame assembly.
My question is , will the LCD + Frame assemblies include the two capacitive buttons? I believe it should because those two buttons are in between the two.
hence if i buy the Frame + LCD assembly then i would not need any heat to make the screen replacemnt.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Here is the link of the repair guide Remplacement de l'écran avec vitre tactile du OnePlus 3
Indice 0
2 commentaires:
This doesn't answer my question...if I buy the LCD + Frame from a third party, do I have to take it apart in order for me to.install the two capacitive buttons?
par
yes, you have to salvage the button from the old screen.
par
If you buy an LCD with the frame it should have the hardware buttons preinstalled as the hardware buttons are located between the LCD and the frame, all you have to do is connect the display, fingerprint and hardware buttons flex cables when reassembling the device. Remember the OnePlus 3's display should be an AMOLED panel and not LCD, make sure you pay attention to this when buying if you want the display to have the same quality as the original. :)
Indice 0
Like Joseph said, make sure its Amoled not LCD. I accidentally bought a LCD replacement display. While functionally it works, it does not look NEARLY as good. It was quite a bit cheaper tho, around $50
Indice 0
Ajouter une réponse
carlos sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,305
