iPhone won't stay in dfu mode long enough to restore?
When I put my iPhone in dfu mode, connect it to iTunes and start the restore process. It reboot it's self
Sorti le 19 septembre 2014, cet iPhone avec un écran de 5,5" est une version plus large de l'iPhone 6.
1) download directly the official firmware
http://www.iclarified.com/750/where-to-d...
Remember where you saved this.
2) Put phone after you finished downloading into DFU mode, open iTunes, and i will ask you to restore.
3) On PC Hold SHIFT+ Click the restore button. On MAC, Hold OPTION + Click the Restore button.
4) Itunes will now let you choose an IPSW file. Choose the one you downloaded in Step1. Restore should then start.
Commentaires:
Worked! Thanks!
par Nicole
Extracting Software still takes too long.
par Jordan Weekley
This doesn’t work for me. The phone disconnects/reboots and I get an error (9)
par T'Saun Seaman
Worked perfectly! Thanks!
T'Saun Seaman you have hardware isssue
par bahroz995
For some reason iPhones have an annoying habit of rebooting while you're waiting for the firmware file to download. Thankfully, you can download the firmware file through your browser and select it manually in iTunes, so the phone doesn't have to wait for iTunes to download 2.5+ GB.
Go to https://ipsw.me/ , locate your model and download the latest IPSW (Apple's iOS firmware file type). ipsw.me links to Apple's firmware servers, so the latest versions are digitally signed, which means you can use them in iTunes.
Put your phone into recovery mode and connect it to your computer. Cancel any dialog options asking if you want to restore or update until you are at the phone's landing page. There should be two buttons on the righthand side of the iTunes window marked "Check for updates" and "Restore iPhone..." On Mac, hold down the "alt/option" key while left-clicking on "Restore iPhone...", and you'll have the option to choose the firmware file you wish to restore with. On Windows, hold down the shift key while clicking "Restore iPhone..."
Select the firmware file you downloaded from ipsw.me and the phone should restore. Doing it this way allows you to download the file prior to putting your phone into recovery mode, so it won't timeout and reboot while iTunes is doing its thing.
Commentaires:
wow thank you so much I finally unlock my iPhone because of your tip
par arleneballenas12
Still won’t finish extraction on my iPad 6 wifi model, keeps rebooting midway to 95% to extraction finish.
Commentaires:
You ever figure this out? I cannot get the phone to stay in recovery long enough to extract the file.
par greg_gorrell
Thank god that actually worked. My iphone 6 while trying to update to ios 12 would go into recovery mode and not come out of it. Then i would get it into DFU only for it to reboot and turn on half way through while updating on itunes. I couldnt even force the update ota because the ‘checking for update’ would just spin and think but not freeze. This is the only option that has worked! Thank you and kudos to you!
Commentaires:
I’m going through the same thing so I hope it works for me too!!
par smilinmsdee73
I'm having the same problem you mentioned. I don't get what you did that worked. My iPhone has been stuck in DFU mode for 7 hours and it's 2am. I downloaded the IOS 12 from OPs site as well as iTunes and both times I've waited about 30min for the iPhone to reboot in the middle of extracting or the middle of updating and it leads to either an "iPhone not found" error or "Error 9/14" on iTunes.
par nellothe1
I have the ultimate answer to this problem. I could restore my iPhone, which was not even detected by iTunes yesterday. When the software is being downloaded in my case through Finder, before the time is up for the DFU mode and the phone exits the DFU mode simply press the home button+power button combination followed by the home button only so the phone restarts the DFU mode. That way you can prolong the amount of time your phone stays in DFU mode and when the download is completed, you are good to go.
Commentaires:
Yes! when you reboot it on DFU mode and press casncel to that prompt with the options it continues downloading.
par Mati Carvajals
Rep: 1
Extracting the software takes too long and the phone exits recovery mode
Commentaires:
Just press the power button once and then volume up and then the volume down and then the home button every 2 minutes to keep it on until finish extract remember now you are not going to press and hold
Rep: 1
It didn’t work.
iPhone could not be restored. An unknown error occurred (32).
Rep: 1
Nothing worked for me. Stuck on trying to get my iPhone 6 plus on recovery mode doesn't stay neither on dfu mode.
Rep: 1
Hi guys this way worked for me, just get an elastic band and use it to keep your volume down button in.
This way your phone will stay in dfu mode.
Rep: 1
Drivers problems. Need to check if all drivers be installed.
May Apple Device Support is missing.
Dernières 24 heures : 46
7 derniers jours : 342
30 derniers jours : 1,705
Total : 66,016
is this while you wait for the firmware to download?
par Eric
