Aller au contenu principal
Pour réparer ensemble - Je crée un compte
My charger cannot insert into my phone
while i was out, i noticed my phone was going to die, so i put it to charge for about 10 minutes and took it out. half an hour later, i decided it would be a good time to leave it to charge again, but the charger wouldn't go in. i then went to try multiple chargers, none of which would go in my phone. i asked a friend and he says there's something stuck in there. i don't know if that's the case because my friend says the charger i used still worked, but i still don't know what's wrong.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Either something is stuck or it's damaged. The actual connector inside the port likes to separate into two pieces after a while. Then you jam in the charge cord and damage the connector. Really common. If you take a close look into the port you can usually check and see if there is any noticeable damage.
Hopefully its not broken, as it's a rough repair to replace the chargeport. I would take it to an awesome technician unless you want to break the LCD and be stuck with a $150+ repair!
Indice 2
Try cleaning it search in the youtube whats the best thing to clean it .just be very careful not to damage the part inside and dont ever put your connector in force it might really break the internal .It will really cost much in solving that issue and definitely will open your device .
Indice 1
Ajouter une réponse
Rachel Harper sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 2,506
