Aller au contenu principal
Repair guides, user manuals, and service manuals for the Acer Aspire V5-573pg. This thin and lightweight 15.6-inch laptop was produced between 2013 and 2014 and was designed for everyday use, balancing performance and portability.
20 questions Voir tout
Noisy fan and overheating problem!
Hi all, my notebook's CPU temp when I run Edge only around 50C, and if I run more apps it starts to get higher and exceeds 60C. In general, fan sounds annoying after 40C 'most time', and it gets worse while the heat is increasing. What could be the possible problem? Does changing the fan solve the issue?
Note:
1) "I cleaned the fan and placed a thermal paste on the CPU".
2) I need the fan to be quiet because I want to record my voice on the PC. At this time I realized that I have a really noisy fan.
Thanks in advance!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Sounds like you need a good cleaning and thermal paste replacement. Luckily, there's a guide to do so, below. Make sure you take static electricity precautions, and unplug the battery. If you don't have any good thermal paste, iFixit has some.
Acer Aspire V5-571 Cooling System Replacement
[produit lié absent ou désactivé : IF179-010]
Hope this helps!
Indice 2
1 commentaire:
Thank you, I'm sure I did that we'll. Dose changing the fan help?
par
Ajouter une réponse
Hazem sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 2,336
