After running awhile scooter dies
Hi first timer here. I am working on a 85' fa50 Suzuki. The owner says he can drive it about a mile then seems to die like no fuel. He tries starting it and gas comes out of the trail pipe. He had somebody else look at it about 2 yrs ago. The other guy said the only thing he could think of was the petcock. Well I just pulled it apart and everything looked good including the diaphragm and O-rings. Any other suggestions. I would really
appreciate them.
Thanks
Update (07/08/2017)
Thanks for the info. I did some more checking it seems the coil, cdi box, and rectifier checked out to be bad
from sitting. I can find the coil, rectifier, and I ordered them. But having problem for CDI box. Does anyone
know where I can find one at a decent price. That way I can get this bike done and go on to the next prolem.
Thank you
1 commentaire
What is a good compression range for a FA-50??? Mine is 90 but have no idea if that is the culprit causing the no-run issue. Spark is good, and I can keep it running squirting eth. into the carb throat.
par pete farr
