Aller au contenu principal
The production third generation Quest was unveiled for the 2004 model year at the 2003 North American International Auto Show.
9 questions Voir tout
Temp rising slightly on highway and transmission slipping in city...
Temp rising slightly on highway and transmission slipping at stoplights in city afterwards. Changed trans fluid (was dark brown) - seemed to fix on test drive towing same camper - temp needle stayed pegged at normal. However, cooling fan turned on immediately when starting van 7 -10 minutes after test drive. Did trans fluid change possibly NOT fix the issue? -KJ
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
When towing with an Automatic, you should never be in the overdrive mode as this will kill your automatic. Did you drop the pan and replace the filter and pan gasket at the same time? If not then no you haven't fixed it.
par
Ajouter un commentaire
1 Réponse
Check your coolant level, transmission filter, your thermostat and water pump. Goodluck bud
Indice 0
Ajouter une réponse
Keith Jeronymo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 119
