Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner.
The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire:
@dano1971 what exactly is going ton with your linkage (AT or MT)?
Its a AT, My shifter is very sloppy and today I could'nt you get the key out of the ignition I couldn't put it in park all the way. I have a check engine light on and the code is p1780 I changed my neutral safety switch. But the light stayed on.
par oldturkey03
