Best Manufactur Adhesive to use?
I'm about to work on my beats and I was wondering what adhesive I should use, that will be watertight and removable when I heat it.
Any silicon based glue will be waterproof and they will not require heat to remove . Any[ https://www.google.ca/search?q=rtv+seala...:| rtv sealant similar] to these. You can also try Goop. Its a very durable sealant that's waterproof. Hope this helps
Does it expand? Would you recommend it when working on this device?
the rtv will be water resistant and does not expand . it will pull apart with some help when you need to take it apart . The goop is a more permanent fix you may not be able to get it apart again . Both are waterproof . The rtv glue is cleanable by simply letting it dry and then peeling the excess off . The goop not so much . If your looking for a more permanent fix use JB weld its waterproof but it is not going to come apart ever again .
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 28
Total : 5,630
