Touch screen partially works
Touch screen has area where It doesn't work so I disconnect and reconnect more times the two flat ribbon cables which link touch screen to board but nothing!
Suggestions please?
Suggestions please?
@rickyleroy anytime you have part of a touchscreen that is not working, you most likely have a failed digitizer. Replacing it will fix your issue.
If I work with virtual keyboard and I push down specific key, character is not lightened and no symbol is written while if I press it with more pressure another near character is typed.
I avoid this behaviour rotating tablet of 90 degree.
What other test can I do?
Where can find guide to replace touch screen for me173x?
I replaced touch screen. Now I noted in landscape mode it works fine while in portrait (vertical) mode, with Asus text in top area, the last bottom strip doesn't work where there the 5 five bottoms. If I rotate device of 180 degree the bottoms works so I suspect specific area has issue. What can I do?
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 473
