Aller au contenu principal
Le Sony Xperia Z5 est équipé d'un écran de 5,2 pouces et à 1080 x 1920 pixels, d'un processeur Qualcomm Snapdragon 810, d'une RAM de 3 Go et d'une caméra arrière de 23 MP.
20 questions Voir tout
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
Répondre à cette question J'ai le même problème
Indice 5
1 commentaire
can i turn off that sensor that make the screen black when covered ?
par
Ajouter un commentaire
6 Réponses
Réponse la plus utile
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
Indice 3
1 commentaire:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
par
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
Indice 2
3 commentaires:
Thanks for this very helpful information
par
Omg it works thank you!!!
par
2023 still using this trick. Tq very much
par
I have that problem also
Indice 0
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
Indice 0
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
Indice 0
i just pressed the top righthand corner and the screen came on !!!** weird or what
Indice 0
Ajouter une réponse
Char Duffett sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 27
Total : 11,766
