Aller au contenu principal
The camera has a 2.7” LCD screen, a 12 megapixel Four Thirds sized sensor, and a built - in flash. Dimmensions are 115 x 72 x 42mm.
Questions au sujet de 15 Voir tout
The small internal date time battery data what type is it, where?
The internal data battery does not hold the date and time when replacing the main battery on my Olympus E-PL1. What type of battery is it? and where is it located?
I hope you can help
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
that sounds write changing a small capacitor inside without a circuit diagram and component list could be dodgy! I am capable with a soldering iron. Olympus service won't tell and want to charge more than the camera is worth. If anybody knows the value of the capacitor ( farads) it will quite small. I should be able to get the component and fix it Thanks rokin154@crowbot.
par
They call these components "super caps". It's possible you could locate it on the board. Likely the farad rating would be kind of high with the voltage being low (5V, 12V). Best of luck.
par
Ajouter un commentaire
1 Réponse
Solution retenue
It's likely that the camera uses a capacitor to keep the clock and memory up while changing the main battery. If the cap fails (as they sometime do) then you'll see this problem. If that's the case the only solution is having it repaired.
I found this during a search. https://www.dpreview.com/forums/thread/3...
Indice 1
Ajouter une réponse
Robbie Cwik sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 24
Total : 1,475
