Aller au contenu principal
A 95.2mm by 56.5mm by 18.3mm point-and-shoot digital camera released in March 2012.
file error message pop up
Why does a file error message pop up when looking through pictures I have taken instead of a picture that I took, but is no longer on camera? instead it says file error with a triangle.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@froggman from the manual:
The following issue can cause a File Error message:
  • The picture file is corrupted
  • The picture was taken with a different manufacturer's camerahe memory card inside your camera is not formatted
  • The memory card in the camera is not compatible or defective and needs to be repalced.
I'd start with formatting the card and see if that works. If not replace it with a new one. you can get the user manual from here which tells you how to format the card etc.
Indice 2
Ajouter une réponse
Justin Hoelscher sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 775
