Aller au contenu principal
Broken headphone jack/USB adapter
I have several Chromebook 3 tablets with broken headphone jacks.  I recently purchased 2 of the Ugreen USB Sound Card External Audio Adapter with 3.5mm Aux.  I plugged the adapter into the Chromebook and headphones into the adapter but the sound continues to come from the built in speakers and not through the adapter.  I tested the adapter/headphones combination on my desktop PC and it worked as it should, sound through the headphones and not the PC.
Any ideas why it doesn't work on the Chromebook?  Is there some internal setting I need to change or ???
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
There is a tool, the GripStick, specifically designed to easily remove broken headphone plugs without having to disassemble the device, use glue, drilling, or any other unsafe method. It also works for any mobile device, tablet, computer, or any other electronic equipment that has a 3.5mm headphone jack.
https://www.youtube.com/watch?v=Ii5OKvtN...
It is made by Nightek (http://nightek.com/), and you can also buy it here on iFixit:
GripStick Headphone Plug Extraction Tool
par
Ajouter un commentaire
1 Réponse
Solution retenue
Most likely a driver issue. Chromebooks probably don't support it. I've had very little luck with external devices on mine, as I've had issue with even getting storage devices to work. Good luck and sorry I couldn't help more.
Indice 0
2 commentaires:
Thank you Reed. I was afraid of something like that. Again, thanks, your reply was very helpful.
par
No problem! Glad I could help. I'm sorry I couldn't provide you with a way to fix it. Good luck!
par
Ajouter une réponse
Ron Holmes sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 1,404
