I just happened to look at the contact number I was getting ready to text and saw that there was a *67 in front of the phone number. How did that happen? I didn't put it there. Does that mean the other person wasn't receiving my text messages?
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
Ok. First start with turning it off and on again. Then try a force restart
To force restart your device, press and hold the Volume down key and Power/Lock key on the device for 10–20 seconds. This performs a simulated battery disconnect
If that doesn't take, then you'll likely have to restore, which you'll want to backup your data
From a Home screen, tap Apps . These instructions apply to Standard mode only.
7 commentaires:
I went to contacts and made the number the default number and the *67 went away. But HOW did it get there in the first place? So when I sent text msgs to this person, does this mean they didn't get them?
If anyone cares (*67) is Caller ID blocking. I have a feeling someone at some point got a hold of the phone and wanted to try to send texts without wanting the person on the other end knowing where it came from.
