Aller au contenu principal
The Vostro was introduced as a business oriented notebook for the average user. Reasonably priced, it was released by Dell in late 2008, and is identified by the model number A860.
3 questions Voir tout
Not seeing the home screen
After switching it, it starts loading then it goes back to the first step of the switching .it goes back before I see the home screen.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@yvette7 I am a bit confused by your question. You need to let us know exactly what your computer is doing and what your operating system is. If it cannot start the OS then it is most likely an issue with the file structure on that and it may need a repair or new install. If it is on the splash screen as your computer loads you do want to try to get into the BIOS and check the settings on that. Consider changing the boot order and use a bootable disk or USB drive to see if that will load on your computer. If so you know that you are having a problem loading your OS. So let us know what you mean by "starts loading" and what "the fist step" is that you see. To access your BIOS try these
Turn on or reboot your computer.
Press "F2" continuously during the reboot process until you see the message "Entering Setup." On some older systems, you may need to press "Delete," "Ctrl + Alt + Enter," "Fn + F1" or "Fn + Esc."
Navigate through BIOS using your arrow keys. Your mouse will not work in BIOS.
Indice 0
Ajouter une réponse
Yvette kagoyire sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 86
