Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone LG Leon LTE est conçu et fabriqué par LG Electronics ; il est équipé d'une application de point d'accès pour le partage de connexion et de nombreuses autres applications Android.
LG Leon MS345 no service after unlocking with the Device Unlock App
Hello, i have one LG Leon from MetroPCs, I unlocked with the App Device Unlock and everything was fine until the next day that i could not make call and it shows me Emergency calls only.
i´ve been trying and the phone not register in the network. Please if someone has the same problem and know how to fix this, i have restored and reflash the device but still the same problem .
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
3 commentaires
Please provide a link to the app you used: https://play.google.com/store/apps/colle...
par Partager
the app is not found in the PS it is an inbuilt app by MetroPC called "Device Unlock"
par Partager
Who's asking me this question Jordan Wright Dominique Berry who
par Partager
Ajouter un commentaire
3 Réponses
Solution retenue
@galmoham ,Unfortunately, flashing a ROM won't help network locks because it is a separate chip. You said you tried to unlock MetroPCS via their "Device Unlock" app. Are you getting "No Service" with the Metro PCS SIM, or did you switch to another service? I would say try a known working MetroPCS sim (maybe go to the nearest store) and see if the known working one works. If you switched to another service, make sure the SIM did not get dislodged, and try that service's SIM in another phone. If it works, sounds like the chip that holds the network lock information was not properly unlocked and is in a bad state. Unfortunately if its in a bad state only a service center or someone with service tools can repair this.
Indice 3
1 commentaire:
i used a friend Octopus Box to unlock another one yesterday it was successfully and working perfectly yet strangely today its also searching and no service...
i have checked all their imei and all are clean.. too bad for this strange fault ...
par Partager
Try resetting the cache to the app. Drag the app out of your app drawer onto "Info" at the top. Form that screen, press "Storage" then clear data and clear cache. That will reset the app. I also recommend force stopping the app, or disabling it. Go back to the "info" page and click either option at the top.
Once you've done all this, do not attempt to open the app again. This will undo everything you just did.
If it doesn't fix it, you'll need to do a factory reset. Make sure you have all of your photos and music and anything else important backed up. Once you do, go to settings, backup & reset, and reset your phone.
Hope this helps!
Indice 0
6 commentaires:
I think I have stated above that I have reset and even reflashed the phone "with stock KDZ. But still the same problem.
par Partager
@galmoham Then I believe @avanteguarde would be able to help.
par Partager
@avanteguarde, I must give you credit, you know a lot about Androids.
par Partager
@pccheese , thanks! :-)
par Partager
There 6 six of this devices with me and 3 of them all behave the same. just after unlocking with the device app it worked normal. then the next day there is a searching and no service. Unfortunately nck box is unable to repair the device (it reported success yet behave the same). There is no MetroPCS sim card and even if there is one to try there would be no service bcos I am out of thier coverage area. No I am afraid to unlock the rest of the 3 left. @avanteguarde. I am a bid confused why the device worked perfectly after unlocked but the next day its something else
par Partager
Afficher 1 commentaire en plus
Hi friend, this is a serious problem but i think that you can enter here. It has a great service for your phone, and you can obtain a solution for your problem. Just ask for yout problem and they will give you a fast solution. I had problems unlocking my LG Leon MS345, and they gave me a code to unlock my phone really fast. Now I can use my phone with any cellphone company without restrictions. I hope it could help you to make your phone works again.
Indice 0
Ajouter une réponse
Abdul Galib sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 29
Total : 3,823
