Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Samsung Galaxy Amp 2 was released in 2016 with the model number SM-J120AZ UD. It is a smartphone running the Android operating system.
How do I disassemble Samsung Galaxy Amp 2 to fix digitizer/lcd display
I have a Samsung Galaxy Amp 2 and the screen got cracked but the display will not come on so it is more than just a broken screen because I know phones can still display with a broken screen. Everything else about the phone still works it is just whatever makes the phone display that is broken. I tried to take apart the phone but there are no screws, I tried to look up a disassembly guide but there are none for this phone. How am I supposed to get the back of the phone off/ the front off (I don't know which side is supposed to come off) and how do I fix the digitizer/lcd display?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Where can I buy the LCD replace screen? Can't seem to find one
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hello, I recently had my galaxy amp 2 break, (Digitizer shattered) and I figured out how to repair. Since there are no screws on the back of the phone that means they are under the screen.
First at the back of the phone, there is a little hatch or cover covering the screen ribbon cable located at the top right of the back, use a spudger or razor to pop it out and undo the ribbon cable. Then using a hairdryer or heat gun to melt the glue sealing the screen to the phone, use a metal spudger or razor blades (exacto knife will do), pry the screen from the edges of the phone and reheat if necessary. After the screen is peeled off, the silver shiny part (digitizer) is also adhered to the motherboard, using a heatgun or hairdryer will do the trick to get it up, be very careful as the digitizer tends to be extremely fragile and can get glass shards everywhere. After the digitizer is removed you can then use double sided tape or adhesive of your choice to install a new screen. If you have any questions feel free to email me at jakubd309@gmail.com Thanks!
Indice 1
4 commentaires:
Thank you very much
par
Can you make a tutorial video? The entire top left of my screen is open (the glass is gone and you can see the hardware) and I have 4 or 5 phone numbers that are important and a lot of important data, and I really don't wanna screw up
par
https://www.youtube.com/watch?v=7wxyfaT3...
This will show you how to do it! Hope this helps! :)
par
got a vid on how to take ir filter off the camera for this phone? oof i do not have a heat gun or soldering iron
par
Ajouter une réponse
Arpeggio Reggiuchi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 34
Total : 3,762
