Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Guides and repair information for televisions made by ProScan.
I have horizontal lines going across my screen
Hey guys, having a similar problem and looking for any guidance!
I have horizontal lines going across my screen. They sometimes change colors with whatever is on the TV. I'm trying to learn how to fix it myself and would appreciate any help!
Thanks!
Proscan Model: PLD3283D
@oldturkey03
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
@speedfisher76 horizontal lines are almost always related to a bad panel. You do want to post some images of what your screen displays with your question. That will allow us to see what you see. Use this guide Ajout d'images à une question existante for that.
Update (09/27/2017)
Thanks for the image. That is a bad panel. Looks like failed Gate drivers
Indice 1
4 commentaires:
@oldturkey03
Is this an easy/affordable fix? Is it something a beginner in TV repair could handle?
I'm not too worried about hurting the TV, but I would like to avoid it as much as I can. haha
par
@speedfisher76 it is very difficult finding the panel. once you do have one it should be a straight forward replacement
par
Ok, good to know. Do you have any resources you could forward to me to help me find and replace it? I am very ignorant in the subject. Is the panel an entire piece of "green board"? Is it a specific small piece on the board? I really appreciate your help!
I'll add a pic to my original comment to see if I'm on the right track.
@oldturkey03
par
The green board is actually part of the panel. You would need the manufacturers label on your panel, it will have the make and model on it. Use that to search for a panel.
par
Sorry to say but your TV is going to stay like that unless you get a new screen installed. Check to see if Proscan has anything on their website that may help you in the way of a recall or extended warranty for your set. My Mitsubishi had the same exact problem that started right after the warranty ended and it just kept getting worse, started with 1 line then 2 then a patch on 1 side then the other. I checked their website and they were offering extended repair time for my set and they came out to my place and replaced the entire screen. that was about 8 years ago and my TV has never had a single problem since, i haven't even replaced the bulb yet after 13 years of daily use!
I have had monitors wit this same issue and it's impossible to repair, it's the contacts that run along the very top of the screen are losing contact with the ribbon that connects on the individual pixels and lights them up across the glass. You might be able to squeeze it with your hands and get it to temporarily work but most likely you'll just make it worse. I tried it on an old dell 27" monitor super wide screen (most of the lines were actually off the normal viewing area, i should have just left it alone because it ended up with a huge area that was all colored wrong. I only pushed on the tape right where the lines were and they went away but as soon as i let go they came back even more. those contacts become contaminated and they get tarnished and loose their contacts, there's thousands of them across the top edge. They separate and they get more air in the area and it keeps spreading like rust. look for a new TV soon, Get a name brand to avoid these types of problems, you do get what you pay for.
I know Mitsubishi is not a brand you would think of when it comes to TV's but I have had a fantastic picture and only the one problem that they covered with a free extended warranty so if this set ever does finally quit I'll only be looking at Mitsubishi TV's from now on.
Hint:Read reviews before you buy any TV's, all manufacturers make bad ones. Find out which models run through bulbs quickly and avoid them, bulbs ae expensive and some are hard to find. Avoid all the bells and whistles, get a good sized monitor that has a good display and has plenty of inputs and don't worry about the sound quality of the speakers, chances are they will never be used. Always turn down the brightness on any TV to keep the heat lower internally and it will also make you light bulbs last for many extra years and will help to keep things like the ribbons from separating as well as keeping the boards cooler so you're less likely to have a malfunction from heat build up and your home will stay cooler too!
Indice 1
1 commentaire:
My tv has just recently developed a few lines again I believe that the problem came about while I was moving the set around to get to the back panel, this is typically what causes the separation of the ribbon from the glass. I also had another problem that started a while ago and it has tobdue with a thin film sheet that's between the front glass cover and the lighted panel? I noticed there were grayish or brownish tones in patches. Really noticable when the screen was dark or dimly lighted screens. Pressing on the cover made it go away but came back as soon as I let go. I'm going to be taking it apart to see exactly what causes it and I'm also going to look at the ribbon connection at the lines across the screen and see if it's even visibly separated. I already picked up 2 other TV's so I'm not worried if I ruin my old one it lasted newly 15 years so I'm happy with it but would like to try and fix it to use as a video game monitor.
par
It is the light reflector panel at the back that came apart. Take tv apart, take screen section apart. At the back of the screen you will see the two pieces of plastic laminated together is making bubbles. Get rid of the bubbles in some way.
Indice 0
Ajouter une réponse
Cody sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 52
Total : 40,103
