Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
My front bumper is coming loose
I recently bout a used 2015 Hyundai Accent. The dealer pointed out that the front bumper was coming loose, and that it would be repaired. When I picked it up, he said that his guy had put a clip on it to fix it, and it did look repaired. Now it is loose again, and I am afraid that if it rubs up against something, it may get worse.
Before I go through the hassle of trying to get the dealer to repair the problem again, how could I fix the problem myself. It is on the passenger side, and the plastic separates for about 7 inches.
Thanks!
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
gatewaynomad post some images of your loose bumper so we can see what you see. Use this guide Ajout d'images à une question existante for that. Most likely it is your bumper cover that is coming off. This from the manual:
  • Loosen the radiator upper cover mounting bolts and clips.
  • Remove the mounting clips.
  • After loosening the front bumper side’s mounting screw, then disconnect the side’s.
  • Push the lock pin, disconnect the fog lamp connector (A).
  • Remove the front bumper.
  • Installation is the reverse of removal
Indice 1
1 commentaire:
That is exactly what I wanted, thank you!
par
My left side bumper is also apart sticking out looks like missing a clip or broke clip.
Indice 0
1 commentaire:
Follow the same procedure listed above if you have the same car.
par
Ajouter une réponse
gatewaynomad sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 30
Total : 11,735
