Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
Restart your iPhone.
If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
Make sure that you have the latest version of iTunes.
Check that your computer has an Internet connection.
Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
Wait while iTunes detects and activates your iPhone:
If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
6 commentaires
no other way because apple change its server
par Marco Centeno
That is my problem too! I tried various chips and different sims but still does't work. Does it mean i can no longer use my iphone?
par Mikaela
Mikaela where you from ?
par Fixie
Same prob. Can i still use this phone? Or should i buy a new phone? :(
par johnbertfaustino
I hard reset my Iphone 6s too now it wont detect my sim card, but it was working on 11.2.1 :(
par NiMR0D9TIN85
Afficher 1 commentaire en plus
