Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
20 questions Voir tout
MacBook 2016 touchbar after only 1 week use won’t turn on
I just broke my MacBook Pro!
I had fully charged it, then travel with plane when I arrived, it didn’t work. I tried resetting SMC, I tried holding the power button in different scenario, I even opened her up disconnected the battery and no luck, I was wondering where are the power pads to jump start the mac?
And what do you guys think happened ?
I did set an appointment but it’s in 10 days and I really need my computer!
Thanks
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
Bummer, Sorry to hear about your computer. Did you spill anything on it during the plane ride?
par
Ajouter un commentaire
2 Réponses
Unfortunately, the 2016 and 2017 MacBook Pros no longer have power on pads.
Update (10/06/2017)
I would try booting it in minimum configuration. Disconnect everything from the logic board, and then plug it into power. The 2016 and 2017s now auto boot when plugged into power. If it is booting in minimum configuration, then you can add components to see what is causing the problem. If it still does not boot the logic board will need replaced.
Indice 0
1 commentaire:
whether the fan is removed too
par
i see, any suggestion ? i had this problem with macbook 2011-2013 and when i disconnected battery and reconnected it it was fixed but in this one nothing helps
Indice 0
1 commentaire:
See revision to my previous comment.
par
Ajouter une réponse
mehrad raissi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,116
