The backlight is not working.
My phone just turned off and then when I turned it on it doesn't lit anymore
@ameliadepp could be the backlight in your display or the backlight driver as well. I would start with a new display assembly. Use this guide Remplacement de l'écran tactile et de l'écran LCD du Samsung J1/J100 for that, If nothing else it will be your known-good point for further troubleshooting. Use these as your guide for further troubleshooting if it should be necessary
Vertical irradiation the screen with a strong light, if you can see the pictrue, the back light is bad and you need to repalce a new LCD screen. If you cann't anything, the display may broken.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 2,988
