Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Écran de 7,9 pouces / Modèle A1432 / Disponible en noir ou blanc / Annoncé le 23 octobre 2012/ avec 16, 32 ou 64 Go de capacité
Which is the best Double tape for Remplaced Screen?
Which is the best double tape to stick the ipad? Or the most advisable glue to stick it?
When mounting the ipad mini I notice that I do not hit correctly.
And what would be the best way to remove the excess tape that comes with the original screen?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Thank you, I appreciate your help
par
Ajouter un commentaire
2 Réponses
Solution retenue
Acetone works well to remove the old adhesive, then clean with IPA. As for the adhesives, the Tesa Tape sold here at iFixit is probably the strongest tape you will find but it is only sold in rolls. If you want pre-cut tape for the iPad, consider BowlerTech or TapeTemplates.
Image Custom cut rolls of Tesa 61395 double-sided tape for repair.
Produit
Tesa 61395 Tape
$8.95
Indice 3
1 commentaire:
par
Personally, I use https://www.amazon.com/gp/product/B00OZG...
Sometimes the factory adhesive is a bit thick and doesn't set very well even with heating, it can also make the home button sit higher so it doesnt make contact.
If you apply about 80C heat to the existing tape it should soften it enough to help peel it back off.
Indice 2
1 commentaire:
par
Ajouter une réponse
Christian sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 47
Total : 5,626
