Keurig shuts off right after I press brew, and the menu option is dead
OK OK I bought it at a thrift store BUT it is really clean, someone took care of it. I would feel great if I can resurrect this baby before surrrendering it to electronic waste.
2 commentaires
My k supreme smart keurig id pot comes on add kcup shut lid starts then stops and shuts off. Anyone know
par Jaimefrog
Thank you all for your solutions! I had a similar problem with the machine turning off. I brewed a first cup but when I tried to brew a second cup, it would shut off. I disconnected it and reconnected it several times but the issue persisted. Then luckily I found this blog and followed several posted answers to fix my problem. I removed the reservoir, took the Keurig to the sink turned it upside down, tapped it a few times, let the residual water drain, turned it right side up, cleaned the needle and put the reservoir back. I connected the machine, set it up for a brew, waited till the water stopped heating, pressed the brew button and bingo it worked. Thanks again everyone.
par Hilda Franco
