Aller au contenu principal
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 questions Voir tout
Phone is not charging in an AC source instead on the laptop only
Hello sir. My samsung galaxy j7 pro is not charging. It is only indicating that it is charging but there's no increase in amount of battery power. And one thing I also observed that it is not charging when it is plugged in on the outlet or AC source but instead it only indicates when the charger is plugged in my laptop. What seems to be the problem sir? Please help. Thanks.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Allen Aranzado make sure that you have a good cable. then check the charging port. Make sure it is not corroded or has debris in it. Clean it with a few drops of isopropyl alcohol and a few puffs of compressed air. After that replace the battery. That way you start off with a known well starting point. This could be an issue with the charging port or even the power management IC. So start with the easy parts and work you way toward the tougher repairs.
Indice 0
Ajouter une réponse
Allen Aranzado sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 87
