Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations de service et de réparation pour le Huawei Mate 8, sorti en novembre 2015. Il fonctionne sous Android OS v6.0 et arbore un écran de 6,0 pouces. En plus d'un capteur photographique principal de 16 MP et d'un capteur photographique secondaire de 8 MP, le Huawei Mate 8 est également doté d'une batterie Li-Po non amovible de 4000 mAh.
Replacing battery without battery adhesive strips, ok or not?
I've already bought a new battery and about to replace it into my Huawei Mate 8. I watched the video showing how to replace the battery from Youtube which mentioned that once taking out the old battery, I need to place two adhesive strips to stick the new battery into the tray. However, I don't have the strips. My question is "Can I just ignore it, and continue replacing the new battery without the strips, or I should buy stripes to make sure everything is good in the long run.
thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi!
You could just install the new battery without the adhesive strips, I think it will still be held in place by the other components. However it may start moving around if you shake the phone if you don't stick it in there like it was.
Indice 2
Ajouter une réponse
Pichai Tachalertsuwat sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 513
