The power button goes red while playing
While playing some music the power light is red and it turns white after a while is new and i don't know what is wrong?
It just means you need to charge it. The battery is running low and it’s letting you know.
mmm, no, it doesn't mean that. It is on the charger.
oh ok thanks for letting me know
i have the same problem. How do i know my UE Wonderboom is charging. Because i plug the usb to charge, i don’t know it is charging or not. I pressed the button and it’s still red. And i just bought it brand new the charger and the speaker, only used one times until i have this situation.
the button should be white and fade/blink and when its full charged it should turn off
if the light is constantly red try to report it to UE or try to do the factry reset (turn it on and hold the power button and minus/volume down button at the same time for like 10-15 seconds it should play a sound and it should turn off)
You should press volume + and volume - same time and also connect to micro USB port , don't turn on press thale volume + and volume - button you will here some door sound that's Mean you're ue wonderboom speaker charge..
This means the mic is off. Can enable/disable in the blast app which also happens to toggle the light. Nothing to do with the battery if the light is solid red.
How do you get the blast app?
I have a red light that says it is al most running out of energy but i am using amazon Music.
My WB was fully charged when I opened it. It lasted for a few weeks before the light went solid red (meaning the battery was getting low). Since I wanted to fully drain the battery before it’s first full recharge, I noticed that it not only turned itself off, but the solid red light was now blinking, meaning it was totally dead. I plugged it in for the first time tonight and it’s now blinking the white/blue color. Hope that helps. Also, I’m curious if there is a green light meaning it’s fully charged, or even a yellow light to let me know it’s half way. Something I read in the manual made me think this would happen, but I guess I’ll find out soon.
Also, I read if you hold down both the +/- buttons simultaneously it will tell you the status of your WB battery.
Going to - my.ultimateears.com/wonderboom
Answered MANY questions.
When it’s fully charged the light will be off. There isn’t any halfway charging status but you can check the battery percentage by clicking the + and - button and it will play a tone then represents its percentage.
Try to do the factory reset (hold minus button and power button at the same time for like 10-15 seconds it should play a sound)
I have a feeling it’s got something to do with the base output. When I play base heavy songs at full volume the light goes red, and when I reduce the volume or change the song it goes back to white
If you play bass heavy music at high volumes it will drain the battery faster. The battery will last for 10 hours with the volume at 50%. Turn it passed 50% and your battery will drain faster, therefore giving you less time.
It means the battery is low and it needs to be charged.
I believe it means it is overheating I tried playing 100 Hertz bass tone on it and it lasted about 20 seconds before it started getting warm on the top and went red
Red light is flashing ..won't charge...did hold down power and volume..still doesn't work
A nice powerful little speaker however there’s not enough info included! Are you supposed to be a mind reader. Where’s the charging light? There isn’t one and there should be one. How the !&&* are you supposed to know if :1. It is charging? 2. When it is fully charged?.it doesn’t say how long it takes to charge!
come one guys, more info is definitely requiresd.
mine was working great then it stopped abruptly.
i tried putting it back on with the cable attached and now it’ won’t connect.
im going to give a 2 hour charge,if nothing changes back it goes to Costco. Thank god costco has an excellent return policy.
One was working great & now nothing. No white or red light, no sounds, just dead. Tried charging it, but nothing. What should I Do now?
Use another cord mine works when I used wireless headphone charger
It means that you have the microphone for Alexa turned off go to your app and turn on the microphone
A red light commonly indicates a low battery on your speaker.
Refer to this video.
Just click the link:
https://youtu.be/t7lqCN-ki6Y?si=9JmKnWdO...
-CHRISTIAN LAWRENCE
Dernières 24 heures : 6
7 derniers jours : 75
30 derniers jours : 370
Total : 34,254
6 commentaires
Does it continue to play music?
par Aiden
Mine continues to play music when the power button turns red. Concerning, as it is only one week old, and I can’t find any info as to what it means.
par ronniejae
On my UE WONDERBOOM, it means that the battery is almost empty. It will continue playing, but it will need to charge soon (up to a few hours depending on the music volume)
par Kloet
I have the same issues as all the above...but even when I have charged it is still showing up red...or is it overcharged so to speak...because I have hardly used it...have only had it for a couple of weeks...so I am stuck...as attempting to charge it IS NOT WORKING!!!
par Jenny Thurling
Have the same experience...have 2 speakers...have been using them for about 3 weeks...charged them at the same time for the same amount of time. On one of them had the power button turn red after the first week...but still works fine..would love to know what that means though.
par phxlost
Afficher 1 commentaire en plus
