Strange behavior flex charging cable
Hi, i have the following issue with the charging flex board.
Hoping to be clear
1) I have 2 G2, one is working (A) and the other one isn't working (B)
On B the red led is blinking if I plug th phone to the supply charger
2) I swap 2 flexes board
Result: now both G2s are working
Basically A with the flex originally in B (that wasn0t working) now is working
And B is working with the flex originally in A (that already was warking)
3) I partially disonnect the flex ffrom the A (remind, it is working with B flex that at the beginning wasn't working), I place correctly various sensors, I connect again the flex: now it isn't working
If I switch 2 flexes, I have the same behaviour of point 1
It is quite clearly the 2 G2s are working but it seems the flex that originally was in B has some issue... what I'm not able to explain myself is the reason why at the beninnig, the first time I switched 2 flexes, both were working but after partially disconnect and then connect again it wasn't working again.
Someone had some similar experience/suggestions?
Thanks
