Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de démontage complet et d'installation pour la plupart des iPod, y compris iPod original, mini, shuffle, nano et touch.
forgot screen lock code, how can i unlock it?
4gb
Répondu ! Afficher la réponse J'ai le même problème
Indice 12
6 commentaires
Please be more specific with what iPod you have. ID your iPod
par
What are you trying to unlock? Which iPod
par
its a iPod touch 5generation and I forgot the screen lock password
par
It's a 3rd generation
par
Afficher 1 commentaire en plus
Ajouter un commentaire
14 Réponses
Solution retenue
you can try several things to unlock your iPod
1) connect your iPod to the first computer you sync'ed it to. Open iTunes, then disconnect your iPod. Your iPod *should* be unlocked now
2) if you don't mind erasing all the contents of your iPod, then restore your iPod. This will remove the passcode lock and restore your iPod to original factory condition.
3) I hear that if your iPod supports disk mode - i.e. can be mounted on your Mac/PC as a USB attached drive, then it may be possible to unlock your iPod without doing a restore. This involves deleting a normally hidden file on the iPod - this file is located on the iPod in:
iPod_Control/Devices - in that directory will be a file named _locked. You want to delete that file (or rename to _unlocked)
on the Mac, you need to run a couple commands in Terminal to [enable the Finder to display hidden files] in order to find this file on your iPod. On Windows, you can set an option in Explorer in Tools-Folder Options-View-Hidden files and folders-show hidden files and folders.
this 3rd method I've not tried myself as I don't have nano to try it (which supports disk mode and has a passcode lock)
Indice 11
1 commentaire:
i know the second method works but i have important things in my ipod
par
What if i dont have the first computer i synchronize my iPod from is there any other way to unlock it
Indice 7
2 commentaires:
Why don't you have that computer?
par
He might of lost it, broke it or given it away
par
how do i get my iPod unlock?
Indice 4
I cantt get on iTunes. cause i cant get on my iPod. everytime i try to get on iTunes it says i have to be on my ipod
Indice 2
3 commentaires:
Lizzy, it would help us a lot if you could post your own answer. Click on the link on the right side of this page "Ask a question" and give as much detail as possible. Stuff like what iPod is it? What has happened to it? What have you tried to fix it etc. will greatly help. Have you tried the very first answer to this question? Good luck.
par
That's My Biggest Problem.
par
I put a lock code on my ipod 8GB HOW CAN i unlock it, it won't let me do anything
par
i forget my screen lock
Indice 2
how can I unlock my ipod 5 its disabled due to too many tries, I was going to unlock it but I hit setting by mistake and it entered numbers on its own and now and now its a password I don't even know?
Indice 2
unlocking a ipad
Update
how to unlock my I pad
Indice 2
Try deleting the file _locked in iPod_control/devices.
This has happened to me and the only possible way i found was to reset factory settings.
Indice 1
I would reset it to factory settings thru itunes
Indice 1
i did it on mine and it wansnt the one i first sycronised it to i dont even have i tunes on this one it should still work mine did
Indice 1
its still lock
Indice 0
1 commentaire:
how do I unlock my iPod Nano 4th generation if I forgot my passcode
Indice 0
1 commentaire:
I don't remember my Gmail or even password
par
I have the same problem but I found a website that could help. Here is the link unfortunately I have not tried it yet but if you could tell me if it worked I would appreciate it. Good Luck :D
http://www.buzzle.com/articles/forgot-ip...
Indice 0
How do i get my ipod unlocked its not a touch screen its a nano. My problem is... I have no way of getting the password to this due to it being a old friend of mines ipod... We lost touch a while back...
I was finally able to charge it after 3 months... Now i forgot about there being a 4-digit password... I don't want to reset it .... It has much valued stuff on it.... Is there anything or anyone who can help me?
Indice 0
Ajouter une réponse
maggie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 125
Total : 37,849
