Aller au contenu principal
Why does my Frigidaire FFPH31M6LM Refrigerator not get cold?
Actually, my product wasn't in the list. It's a Frigidaire FFPH31M6LM Compact Refrigerator: https://www.google.com/shopping/product/...
It has a separate freezer - that's fine. The fridge is about 60 deg. I tried moving the dial from one end and waiting, and then to the other and waiting. Not very cold.
I guess the compressor is fine... why isn't the fridge part getting colder?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
update - I turned the dial to one end and the other, there was no 'click', other than turning it off, and the light went off as well. Bad thermostat?
par
Ajouter un commentaire
2 Réponses
Solution retenue
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Cause 2
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Cause 3
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Indice 2
Hi mayer,
Thank you for the suggestions. I checked, and I don't see any coils or fans. I did lean it back, and heard a noise in the big black thing. Not sure what that is.
This is the fridge upside down.
There is a kind of plastic, "sign board" kind of material along the back. I didn't see how to remove it.
Do you think it's the black thing or do I have to cut that sign board material away?
Indice 0
Ajouter une réponse
Eric sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 65
Total : 16,924
