At the very beginning hold down the Power rocker for a short while in order to turn on the device.
After that, go the Menu and find and select Settings.
In the next step choose Backup & Reset and tap Factory data reset.
Then choose Reset device and select Erase everything to confirm the whole operation.
or
Android tablets by Coby allow users to lock their devices using a pattern screen lock. If you are unable to log into your Android tablet, or have forgotten the pattern screen lock, you can either reset the lock pattern through Google or restore your tablet to the original factory settings.
Attempt to unlock your Coby Android tablet at least five times. After the fifth attempt, a message will display on-screen explaining you were unsuccessful at unlocking your tablet.
Tap on the option to make an emergency call, then quickly press the Lock / Power button on your device.
Press the Lock / Power button again within 30 seconds, then tap on “Forgot pattern?”
Sign into the Google account associated with your tablet.
If you are unable to sign in to your Google account, follow the steps outlined in method two of this article to reset and unlock your tablet.
Draw a new lock pattern, then tap on “Continue.”
Draw the new lock pattern a second time, then tap “Done.” Your Coby Android tablet will now be unlocked.
https://www.wikihow.com/Unlock-a-Coby-An...
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
