Aller au contenu principal
Lumières décoratives utilisés aux alentours des vacances.
Questions au sujet de 22 Voir tout
Incorrectly connected LEDStrip Light to the energy supply
So, a friend of mine, has bought a LED Strip Light, and connected it to the dimmer. He connected entirely the whole strip (around 5 m) and he connected it to the IN connection, and the energy cable to the OUT connection of the supply, when it was intended that the strip should be connected to the OUT, and the energy cable to the OUT.
When he plugged in the dimmer, th e strip bliked and has turned off. After this, he tried to swap places the strip and energy cable (this time he connected it correctly), but again the strip bliked and turned off, is it in a working state, or is it dead?
I've reviewed the LEDs again, and I've noticed a tiny crack, and a black point on each of them. Here Is an image, where is shown what happened with the LEDs With red I've pointed the crack and that tiny point, and with blue- the resistor (which is before each LED.
P.S. It is a simple LED stripe without any programable chips
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
It sounds like the strip has died, LEDs generally don't die from this but if they are programmable there is a chance you fried the chips which control individual LEDs.
Indice 1
3 commentaires:
It is a simple LED stripe, it has just one resistor before each LED. BTW I've noticed that each LED has a tiny crack in the part where is marked -, does it mean that they are dead, or they can still function. Oh, and That Energy supply is actually a dimmer, not an energy supply, sorry for misunderstanding
par
I'll post a foto for understanding what I mean
par
Yes, unfortunately that black dot means the LEDs have burnt out.
par
Ajouter une réponse
Eugen-Andrew Coliban sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 95
