Aller au contenu principal
The HP Pavilion dv9000 series was introduced in 2006.
50 questions Voir tout
Why does it shut down when touching the touch pad?
My laptop works fine until i put my hands on the touchpad then, its shuts off and reboot itself.
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
1 commentaire
i can't use my laptop anymore:-(
par
Ajouter un commentaire
1 Réponse
Solution retenue
Can you attach a USB mouse and disable the touchpad and see if it works as it should without the touchpad
1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
2. Double-click Mouse in Control Panel, and then select Disable .
3. Click Apply , OK .
Also try to remove your battery which is housed underneath it I believe and see if you have the same problems w/out the battery, just run it on AC.
Indice 1
Ajouter une réponse
dijae10 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,804
