My cell does not start
when i turn on the phone se logo appears and then the screen becomes bluish and then white.this process repeats again and again
First, turn your phone off, wait for a couple minutes and on it again. If you find this worked then the error happened with the software. It can be resolved by doing the power-cycling.
Second, remove the battery and sim card if you have one, while the phone is still in a turn on position. Wait for a couple minutes and put the battery and sim card back. Restart the phone and check the result.
Also check on Here and here is more Support for your phone. Good Luck and let us know what happened
If your phone doesn't start, remove sim card and memory card if have it.
Then, place the battery without sim nor memory card and do a master reset.
This will format your device, so, all pictures, music, contacts or phone numbers, messages, games, notes and all things stored in the mobile phone will be erased, so proceed at your own risk.
First, make sure your battery is fully charged. If the battery is drained out, it may take up to 30 minutes of charging before the battery-charging icon appears on the screen. Remove the battery during 30 seconds and place it again.
Press the On/off key for a minimum of 10 seconds to turn the phone on.
It should work.
If this does not work...
Try to update software phone by firmware upgrade using Sony Ericsson Software Update application or PC Companion. Connect the data cable and follow the steps in the wizard.
Sometimes, to be recognized by the Software updater program, you should to keep pressed (C) key or (<-) (Back key) or perhaps both keys and connect the data cable.
If anyway it does not work...
Try to turn on your phone by keeping pressed (C) key while turn on your phone. If nothing happen, keep pressed (C) and back key (<-) at the same time while turn on the phone. Some others require only the back key (<-) pressed while turning on the phone.
It should format your phone.
Good Luck.
my phone was not on suddenly why idont no
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 26
Total : 9,758
