Home Button not position properly
I replaced the screen that came without a home button and when I went to attach the older one I used loctite to attach to the new screen. needless to say i did not correctly get it centered and the home button does not work properly.
I did try offsetting the bracket with the two screws to center the switch under the home button using on screw. Now it works properly and can i make a small hole in the mount and screw the bracket on or should i glue it?
Otherwise everything is working great.
Thank you,
Bill Haymaker
