Aller au contenu principal
Modèle A1238 / avec disque dure de 80, 120 ou 160 Go / façade en métal noir ou argenté
Questions au sujet de 890 Voir tout
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
Répondu ! Afficher la réponse J'ai le même problème
Indice 14
4 commentaires
It worked, oldturkey. Thank you for protecting me from my own karma.
par
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
par
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
par
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
par
Ajouter un commentaire
2 Réponses
Solution retenue
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
Indice 20
32 commentaires:
Had same problem. Solution worked. Thank you very much.
par
awesome...problem solved...thanks
par
Nice. Thank you. Problem solved!
par
Thanks so much! worked perfectly
par
@Matt Tierney, you are welcome :)
par
Voir 27 commentaires en plus
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
Indice 0
1 commentaire:
Yea as this is where the "Tunes" are kept.
par
Ajouter une réponse
Danielle sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 54
Total : 47,836
