Toner Waste Bin Error message
I removed and replaced the Toner waste Bin and now I get an error message to "Replace/Install Toner Waste Bin." How can I clear this error?
Check it's seated properly.
This made no difference.
Please check whether the clear plastic "windows" in the bottle side are clean. The system "sees" the toner level through those "windows". Try and keep them clean (otherwise the system will think the bottle is full of waste toner). Take care NOT to blow, you would spill toner everywhere! Gently tapping the bottle on a hard surface is usually sufficient.
You may need to clean the inside, I've used a few drops of laundry detergent and let it sit for around 10 minutes then washed it out in the bathtub and poured a bit of 99% rubbing alcohol, let that sit, washed that out, put it back in, and all good.
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 737
