Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Conseils et astuces pour profiter au mieux d'iFixit.
4mm Bit extension options?
Hello,
My BF had gotten me the 54 Bit Driver Kit from Ifixit years back as a gift and I've lost count on how much money it's made me between my two jobs and my moonlighting, but I recently got into more miscellaneous electronic repair and scrapping and a lot of the stranger devices/appliances require a longer/thinner driver than the Ifixit one. Does anyone have any suggestions for a good, durable extender that doesn't add much thickness, or even a different longer driver that I can also carry with me?
Thanks,
Derek.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
7 Réponses
Solution retenue
See https://meta.ifixit.com/Answers/View/103...
I asked a similar question on iFixit Meta some months ago and came across you question in searching for it again. I was told my suggestion would be put to the Tools Dev Team but haven't heard anything since, which is a pity because I have a birthday coming up.
Indice 0
1 commentaire:
I'm trying to understand why this is earmarked as the solution when it answers nothing! All I'm seeing here is where another entity, ifixit, is having the same issue which we are seeking a solution.
par
Réponse la plus utile
Wiha makes one called System 4 Magnetic Extension Blade for Micro Bits Part# 75901 its super narrow for getting into recessed screw cavities and can be stacked to reach even further. The only setback is its not very magnetic so you might have a hard time picking up larger screws.
Indice 3
2 commentaires:
Bradford, thanks for the recommendation. Picked up a couple of Wiha 75901's from Digi-Key, and has already proven useful for opening a game console. Good stuff.
par
where can I buy it
par
I bought a specific Torx set with about 5-6” shafts which eliminated the extender bulge. Many times ANY bulge will create a problem so I would look for what you need with the long shaft instead of an extender.
Indice 0
1 commentaire:
Indeed, the ideal is to have the right screwdriver for every screw - fine if you're in your own workshop with plenty of space for storing a galaxy of tools but we're not always lucky enough to be able to enjoy that. Before the pandemic (and hopefully again in the coming months) I used to attend pop-up community repair events, often travelling by train and/or bus and sometimes up to a mile's walk, and with no idea what challenges I might face. Along with all the other tools, it's then necessary to maximise usefulness whilst minimise weight and bulk, and a driver and set of bits is then the only sensible option and an additional range of long screwdrivers is not an option.
par
Hi @pleriche ,
I also attend community repair events and I’m also looking for a solution.
The solution proposed by @cspanpacman seems reasonable but I'm afraid that the buldge would still cause problems, like @ruggb emphasized (at least for the skinniest bits).
How do you manage this problematic in the meantime of an optimized solution?
Personally I was lucky enough to always have a fellow repairer that comes with his huge tool case ready to lend me longer shafts. But I would be more confortable to have an skinny extender. In terms of production footprint (and cost for our wallet) a good extender would save lots of long shaft versions for each bit we could need…
Do you think a good extender would be impossible considering the (failed) attempt of iFixit’s tool development team? (https://meta.ifixit.com/Answers/View/103...)
In short for future folks coming here, according to you, what kind of conclusion could we make about this problem ?
Best regards,
Geoff
Indice 0
1 commentaire:
Hi @geoff5 - I still don't have a real solution. I have a set of 50 75mm 1/4" bits that I usually take with me, but they add a fair bit to the weight and arn't always long enough. You would have thought it'd be possible to make an extender consisting of 6 pieces to grip the bit inside a thin but very high tensile band to hold them together. But what do I know?
par
Note that as of February 2022, the Wiha magnetic extension suggested by Bradford May 2021 has been reported by DigiKey as discontinued by the manufacturer.
Indice 0
2025, Found this on eBay for ~$13/14 USD. Worth it for me. Already found that I need it and the whatever-its-for wiggly useless extension just doesn't have any use for reaching recessed holes:
https://www.ebay.com/p/7012058762
Indice 0
Wiha 75900 seems to be the same extension bit as 75901 but with slots that don't appear to affect holding 4mm bits. Its available through Mouser for 6.30 plus 7.99 ground shipping to TX. I order a couple things regularly from Mouser so shipping is essentially free that way.
https://www.mouser.com/ProductDetail/596...
Indice 0
Ajouter une réponse
Derek sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 101
Total : 5,141
