The Dodge Dakota was developed by Chrysler as a mid-sized pickup. To keep investment low, many components were shared with existing Chrysler products and the manufacturing plant was shared with the full-sized Dodge D-Model.
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire:
Check all your wiring at the sender. Make sure you are getting a good earth signal. aka clean earth point. Also see if you are getting any power. Unless it has a fuse for it, which might be unlikely. Find which wires run to your fuel gauge on your cluster and trace to wire harness again see if you have power and earth. It could be that your sender unit is dead, but best to check everything else first.
par sm_vulkus
