Xbox one disc drive malfunction
I finally reformatted one of Xbox hard drives I had sitting on my shelf. I install it, I boot it up, and I go through setup to make sure everything works and resale it.
Then I inserted a Blu-ray. It made a strange noise after the disc was already in, like it still was trying to feed. It doesn't register a disk at all. So I opened it up and that's exactly what is happening. But the drive still detects a disc is because it lets me eject. So I opened it up:
@tronicsfix @tomchai either of you know if this looks normal, and is this a regular problem?
Update (02/11/2018)
Here's the video of the noise and roller:
Update (02/18/2018)
Is this the slider?
perhaps the belt gets greasy somehow and loses traction.
@tronicsfix I could really use your help if it's not too much trouble.
par George A.
Hi actually you can remove the upper case of the drive. Unclip the black faceplate from the case and slide the whole mechanism out of the front. Observe the lever mechanism on the top, take a video so we can see as well.
par Tom Chai
That's great! I might have to make a opening video of this thing.
par George A.
Stick a cotton bud in it and go side to side cleans the gunk of . Or hold disk let it try pull it in . Pull disk out clean disk and keep doing until the roller doesn’t leave residu on disk . Worked a treat on mine
par neonwt
