Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Guides pour la version Wi-Fi de l'iPad Mini 4-modèle A1538. Annoncé le 9 septembre 2015, l'iPad Mini 4 est le successeur de l'iPad Mini 3.
Why won't my iPad mini turn on?
I was on an app and it crashed. The screen went grey, so I tried to restart my iPad by holding down the power button and the home button simultaneously. My iPad turned off, but it never turned on again.
My iPad mini is new, I bought it less than six months ago and it is in perfect condition. I have had no previous problems, and haven't dropped it or anything.
I tried holding the power and home button simultaneously for 30+ seconds and still nothing has happened. I have charged it, held just the power button down, just the home button, the volume buttons, holding the power button for five seconds, and the home button as well for 15 more but still nothing. I have also tried to connect it to my laptop, but the screen is still just black.
I don't know what to do. Please help.
Répondre à cette question J'ai le même problème
Indice 4
1 commentaire
1. If your iPad mini is not responding, you need to try quitting the app. To do this, double press the Home Button, tap and hold on the app until it jiggles, then press the (-) sign to close it.
2. If your device is still unresponsive, try resetting your device.
https://bit.ly/2kPawyD
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Could you try and put it into DFU mode at all in your computer? Keep in mind you'll lose everything if you do this. Hold power and home button while its connected and after 10-15 seconds let go of the power but keep holding the home button. Otherwise you could try and connect it to a program called iReboot and see if that works, either that or 3uTools
Indice 1
1 commentaire:
I tried, but it doesn't detect it when I plug my iPad into my laptop. It wont connect to iTunes, or detect its plugged in on iReboot
par
Have you tried keeping it plugged into a wall charger to see if it will power on with apple logo again?
Make sure that the wall charger is an iPad charger (5V 2.0A or higher rated) and you are using a good quality charging cable (basically original).
Indice 1
1 commentaire:
Yes, still nothing happens.
par
I’m curious to know if your issue had been resolved. Was it the PMIC chip? Was it the Dock connector? Power button?
I am eager to know as I am experiencing the same problem
Indice 0
Ajouter une réponse
Danielle McComish sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 23
Total : 4,818
