Aller au contenu principal
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
Questions au sujet de 24 Voir tout
wires came loose as I was removing battery, how to repair?
I was following instructions to remove the battery from my Flip Mino Hd. I hadnt used in it years and tried all else to turn on an retrive video. Noticed two wires unsoldered from motherboard during the process, one red, one black. The other two remained in tact. Can I solder them back on and if so, how?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@fixerchick those are most likely the power leads from the mic. Post some images of your board so we can see which wires are off. Use this guide Ajout d'images à une question existante for that. It will allow us to see what you see. Of course, you can also take a look at this image
from here Remplacement de la batterie du Flip MinoHD to see if that shows the wires you are referring to.
Yes, those can simply be soldered back to the board. Check videos like this one or this one or this guide Comment souder et dessouder des connexions to get a feel for what you need to do.
Image Soldering
Tutoriel
Difficulté :
Difficile
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Image Flip MinoHD Batterie
Tutoriel
Difficulté :
Modérée
15 minutes
Indice 1
Ajouter une réponse
Celeste Gurney sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 158
