Aller au contenu principal
Valve Steam Controller, released November 10th 2015. Model 1001.
20 questions Voir tout
Button stuck down how can I clean this
I have sibling who spilt coke on my controller everything else works except b button is stuck how can i clean it the easiest .
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
two options.
the best of them is to open it up, and clean it out by disassembling it, then scrubbing it with a 99% isopropyl, and a toothbrush.
the other option is to spray it with a deoxidizing electronics cleaner, and let it soak, then scrub the button with the same isopropyl stated above.
Indice 2
2 commentaires:
Thanks this fixed my controller and buying 99% isopropyl is cheaper then a new controller
par
happy to have helped. i do this every day for my customers. saves a lot of money than replacing.
par
First, you should do the obvious; if you haven't already you should wiggle the button around in order to get it loose. I'd also blow it out with canned air, you should be doing this on a regular basis anyway.
If all else fails, you may have to disassemble the controller and clean it from the inside.
Indice 1
I've disassembled mine and found the rubber tactile mesh has snapped :(
Can't find a way to buy spares anywhere...
Indice 0
Ajouter une réponse
Damon Diller sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 4,471
