Aller au contenu principal
A series of 40 inch LCD HDTVs by Sony.
Questions au sujet de 185 Voir tout
SONY LED Screen Lines
I have horizontal lines appearing on my 52 inches LED, Sony Bravia LED , they're on the lower half of the screen, and there is a thick dark dotted line in the middle and below that the image is blurred, how should I fix it?
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
There are 6 horizontal lines on the screen of Sony bravia and also the the dots at the starting of those lines
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
many different things can cause this. have you recently moved the television, or has it been impacted or had liquid on it recently?
1) always start with a settings reset. it doesnt sound like a settings issue, but it doesnt hurt to try.
2) Make sure your source is functioning properly. check a different source, with a different cable, on a different port, and make sure it isnt any of the things listed.
3) crack the device open, and run through the connectors to the LCD. make sure it isnt anything loose.
4) while looking for loose connectors, keep an eye out for blown components, as well as signs of corrosion. repair as necessary.
5) if nothing above fixes the issue, you are looking at one of two things needing to be replaced. The LCD, or the Logic Board. Replace the components one at a time to see which one needs to be done.
Indice 2
Ajouter une réponse
Muneeb Hassan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 34
Total : 13,626
