broken COWIN Bluetooth Headphones.
I broke the left side under the part that you extended it.
Right where moves left and right.
Hot glue does not last for a minute.
I don't know if I should different glue.
Is there any good temporary fix until it's completely fixed?
Any help is appreciated
[COWIN E7 Active Noise Cancelling Bluetooth Headphones with Microphone Hi-Fi Deep Bass Wireless Headphones Over Ear, Comfortable Protein Earpads, 30H Playtime for Travel Work TV Computer Iphone - Black https://www.amazon.com/dp/B019U00D7K/ref...]
21 commentaires
I also have that problem!!! u ever get your's fixed yet??? or does anyone else on here know how to fix them??
par chris owens
It's not fixed yet. I don't know if glue is the only way, so far only 44 have seen this post.
par Andrew Hathaway
I used super glue and it works perfectly although shocking that I had to do this repair at all
par Gino Giuliani
You have to pry the little silver piece off the inside of the headphones to reveal 2 Philips head screws. Remove both screws and separate the 2 pieces. once separated there is a small u type retaining clip that slips into the groove just above the dull white plastic piece that is pictured in the first picture above. Clean that groove out so the clip fits in it properly. Slightly squeeze the tips of the clip together to give it a tighter fit, then reassemble. As long as the piece that sticks out that goes into the ear piece isn't broken off, this should fix the problem.
par Bert Einstein
what are the tips of the clip i dont see them anywhare
par elismart13
Voir 16 commentaires en plus
