97 disco Barely running After warming up
My 97 Land Rover discovery starts acting up once it warms up....such as, misfiring, backfiring, no power, can't go over 40mph down hill, barely goes 10mph up hill. After 40mph, when I push on gas pedal it does absolutely nothing. The same effect you'd have if You just weren't pushing it at all. Once it drops below 40mph the gas pedal registers again...... Any suggestions?
If you can get it scanned, do that first. See what codes are coming up. Also vacuum leaks will cause all kinds of problems. Check all your vacuum lines for splits, breaks or brittleness.
par sm_vulkus
We put a scanner on it and it comes up with codes for o2 sensors, camshaft position sensor, random misfire, and then some others that say check service manual. About 10 codes altogether.
par Amber Deterding
We did however find a vacuum leak but didn't help after fixing it. And thank you for your comment I'll take any advice I can get
par Amber Deterding
@adeterding any chance you can post the codes on here?
par oldturkey03
Camshaft position sensor is an important one. Will cause what you describe. Could also be the reason for setting the random misfire codes. However as OT03 mentioned, would you mind posting all your codes so we can better help you diagnose your issues.
par sm_vulkus
