Replaced the fuel pump in 1999 grand prix but after putting gas in it
After putting gas in it wont start the fuel pump was replaced any ideas need to know what im getting into before i buy it
Oh no ! you ran outta gas and it sat with an empty tank !
OR, its been sitting since Bush was prez.
But first,,, did you see the old pump that was removed ? Was it shiny and clean ?
Did the rubber parts appear to be nasty, melted, or rotted ?
What happens with our modern alcohol-gasoline is that it absorbs water and melts rubber.
Both of which is fatal to a old gas tank.
Is this a D.I.Y. problem ? You must remove the gas line near the engine and test the fuel pump pressure.
Without the proper pressure, the computer is no-go.
A shade-tree mechanic would squirt some gas into the air intake to see it would fire.
I do not recommend you trying any shortcuts like that. The keyword is fire !
Oops, I jumped pass the 'before I buy it'.
No, not until it can pass your state's emissions test. You could be looking at a $500+ problem.
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 7
Total : 83
