Pinout for Charing port
Hey all does anyone have a pin out of the usb charging port on the Ipad Mini 2?
Here is a image that shows where you have to connect the missing pad. Look for the red :>)
So the red dot is also power from the usb connector since it seems I'm missing those 2 red pins?
Also, what would the ground be located?
To find ground, just put one multimeter probe on a shield and then use the other probe to check the pins individually. Then look for 0 Ohm readings or a beep in continuity mode.
Thanks @Minho. This pin for power would be the one that allows it to be charged as well, correct?
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 476
2 commentaires
Is this on logic board?, if the pin is missing u need scratch, to make new pin
par Sham Kumar
i dont even know what pin(s) are needed - thats what i need to find out.
par David
