Aller au contenu principal
Les Toshiba série Satellite C660 offrent un traitement efficace, une capacité de stockage et un lecteur DVD Super Multi Drive pour regarder vos DVD. Il a un écran de 15.6 pouces (39.6 cm) Toshiba TruBrite® de résolution HD avec rétroéclairage LED.
20 questions Voir tout
Why is my laptop making sound like something is moving inside?
Hi,
It has been few weeks now that my laptop make weird sound inside. I open it because it wasn't turning on correctly and then I saw a piece of tape that wasn't on any component. Then I thought that piece of tape was making noise with the fan but now the computer turn on but stay with a black sceen with the underscore flashed and the noise is still there.
Any idea?
Thanks.
PS: Sorry for my english.
Répondre à cette question J'ai le même problème
Indice 4
1 commentaire
What kind of sound?
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
The devices capable of producing some sound inside a normal laptop are the fan and the hard drive. When the fan is not attached properly, due to some screw or broken part, then there will be reasons for noise. In the case of the hard disk, this only makes a noise when tired.
Solutions:
- securely fasten the fan and make sure that all the connectors are secure;
- remove the hard drive and check if the noise continues;
- disconnect the fan connector and check if the noise continues;
Indice 3
I also had strange noises coming from my laptop. It made crackling and swishing noises when I moved the laptop or when typing. Turned out it was because my microphone was constantly on and thus picking up all noises from inside laptop or something. As soon as I disabled the microphone it stopped. Not sure if you had the same problem, but someone out there might….
Indice 2
1 commentaire:
Your advice is a life saver.
I disabled the microphone access and I didn't hear those squeaky noises !!
par
don’t sit alone in the evening, demons have entered your laptop
Indice 1
my laptop is sound like tunder
Indice 0
Ajouter une réponse
RICARD sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 37,347
